Displays the MSRP configuration on the switch.
| msrp | Multiple Stream Registration Protocol. |
N/A.
Use this command to display MSRP configuration on the switch.
# show msrp MSRP Status : Enabled MSRP Max Latency Frame Size : 1522 MSRP Max Fan-in Ports : No limitMSRP First Value Change Recovery Time : 10000 (ms)MSRP Ignore Latency Changes : OnMSRP Talker VLAN Pruning : OnMSRP Enabled Ports : *17ab *19a !5 Total MSRP streams : 4 Total MSRP reservations : 2 Flags: (*) Active, (!) Administratively disabled, (a) SR Class A allowed, (b) SR Class B allowed.
This command was first available in ExtremeXOS 15.3.
The MSRP First Value Change Recovery Time, MSRP Ignore Latency Change, and MSRP Talker VLAN Pruning example outputs were added in 15.3.2.
This command is available on all platforms that support the AVB feature and that have an AVB feature pack license installed. To see which platforms support AVB and for information about obtaining a license, see the Switch Engine v33.1.1 Licensing Guide .
